跳转到主内容
加入维修社区 - 创建账户
PowerBook G3 Lombard Modem Replacement
你所需要的
    1. PowerBook G3 Lombard Modem Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Turn the computer so that the ports are facing you.
      • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard Modem Replacement: 步骤 2 中的图像 1,1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
      询问修复机器人
      添加评论
    3. PowerBook G3 Lombard Modem Replacement: 步骤 3 中的图像 1,1
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
      • In order to replace the keyboard, you must first remove the modem.
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard Modem Replacement, Heat Shield: 步骤 4 中的图像 1,1
      • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard Modem Replacement: 步骤 5 中的图像 1,1
      • Lift the heat shield up and pull it toward you.
      询问修复机器人
      添加评论
    3. PowerBook G3 Lombard Modem Replacement: 步骤 6 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard Modem Replacement, PRAM Battery: 步骤 7 中的图像 1,1
      • Pull the battery cable directly up from the logic board.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard Modem Replacement: 步骤 8 中的图像 1,1
      • Remove the battery from its holder by pulling up and to the left.
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard Modem Replacement, Modem: 步骤 9 中的图像 1,1
      • Remove the two silver Phillips screws from the modem.
      添加评论
    2. PowerBook G3 Lombard Modem Replacement: 步骤 10 中的图像 1,1
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
      询问修复机器人
      添加评论
    3. PowerBook G3 Lombard Modem Replacement: 步骤 11 中的图像 1,1
      • Disconnect the cable from the right side of the modem.
      询问修复机器人
      添加评论
    4. PowerBook G3 Lombard Modem Replacement: 步骤 12 中的图像 1,1
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 28
总计 3,291
