当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the computer so that the ports are facing you.
If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
In order to replace the keyboard, you must first remove the modem.
Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
Lift the heat shield up and pull it toward you.
Your laptop should look approximately like this.
取消:我没有完成这个指南。
另外一个人完成了本指南。
G3-Lombard-Screw-Guide.pdf
PDF - 354.56 kb
与1其他贡献者
于09/24/09注册
1 声望
创作了636篇指南
徽章: 36
+ 33更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,537
