跳转到主内容
PowerBook 3400 M3553 RAM Replacement
你所需要的
  1. PowerBook 3400 M3553 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 RAM Replacement: 步骤 2 中的图像 1,2 PowerBook 3400 M3553 RAM Replacement: 步骤 2 中的图像 2,2
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 RAM Replacement, Keyboard: 步骤 3 中的图像 1,1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 RAM Replacement: 步骤 4 中的图像 1,3 PowerBook 3400 M3553 RAM Replacement: 步骤 4 中的图像 2,3 PowerBook 3400 M3553 RAM Replacement: 步骤 4 中的图像 3,3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 RAM Replacement: 步骤 5 中的图像 1,2 PowerBook 3400 M3553 RAM Replacement: 步骤 5 中的图像 2,2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
  6. PowerBook 3400 M3553 RAM Replacement, RAM: 步骤 6 中的图像 1,2 PowerBook 3400 M3553 RAM Replacement, RAM: 步骤 6 中的图像 2,2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
结论
To install the new RAM card, follow these steps in reverse order.
2等其他人完成本指南。
团队
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G59
4 名成员
创作了9篇指南
1指南评论
To reattach the keyboard I found it necessary to keep the kid open and push the keyboard all the way down; otherwise, the screws didn’t engage.
Scott - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 2,868
