跳转到主内容
PowerBook 3400 M3553 Hard Drive Replacement
你所需要的
  1. PowerBook 3400 M3553 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 2 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Hard Drive Replacement, Keyboard: 步骤 3 中的图像 1,1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 4 中的图像 1,3 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 4 中的图像 2,3 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 5 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
    I did find that, strictly speaking, you don’t need to remove the ribbons. If you carefully hold up the keyboard up towards the screen with one hand, you can remove the old RAM and install the new one with the other. I suppose you could also use a length of masking tape to hold the keyboard up.
    I found it easier not to remove the ribbon, especially as I couldn’t find my plastic opening tool.
    Scott - 回复
  6. PowerBook 3400 M3553 Hard Drive Replacement, RAM: 步骤 6 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement, RAM: 步骤 6 中的图像 2,2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
  7. PowerBook 3400 M3553 Hard Drive Replacement, Speaker Panel: 步骤 7 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement, Speaker Panel: 步骤 7 中的图像 2,2
    • Disconnect the wires from the port.
    Speaker panel? I don’t think this is correct - I accidently pulled the black & red wires out from this part and sound still worked fine. Is this instead a battery connection?
    Matt - 回复
  8. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the 7mm screw connecting the speaker panel to the computer.
  9. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 9 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 9 中的图像 2,2
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
  10. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 10 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 10 中的图像 2,2
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
  11. PowerBook 3400 M3553 Hard Drive Replacement, Track Pad Panel: 步骤 11 中的图像 1,1
    • Push the display screen back to give yourself enough space to remove the side panels.
    • Before removing the side panels, note that removing the side panels hastily will damage the underlying panel screw. However, this will not affect the functionality of your PowerBook.
    • Remove the panels on either side by gently but firmly pulling up on them with both hands.
  12. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 12 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to lift up the tabs on either side of the ribbon cable port and then gently pull the ribbon cable free.
  13. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 13 中的图像 1,3 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 13 中的图像 2,3 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 13 中的图像 3,3
    • WARNING: There is a high risk of breaking the tabs that lock the panel to the casing. Remove the panel slowly and cautiously to avoid damage.
    • With your index finger and your thumb, squeeze the track pad panel to loosen the clamps. Then slide the panel towards yourself.
  14. PowerBook 3400 M3553 Hard Drive Replacement, Hard Drive: 步骤 14 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement, Hard Drive: 步骤 14 中的图像 2,2
    • Remove the three T8 10mm long torx screws along the bottom of the casing next to the hard drive.
  15. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 15 中的图像 1,1
    • A ribbon cable is attached to the underside of the hard drive. Hasty removal of the hard drive can damage the ribbon cable.
    • Gently lift up on the hard drive.
  16. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 16 中的图像 1,2 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 16 中的图像 2,2
    • Rotate the hard drive towards yourself to access the ribbon cable and then gently pull up on the ribbon cable connector to remove the cable.
    • You might find it easier to set the hard drive on its side while disconnect the ribbon cable.
  17. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 17 中的图像 1,1
    • Place the hard drive so that the casing is facing up.
    • Remove the 4 T8 5mm long torx screws to remove the hard drive from the metal casing.
  18. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 18 中的图像 1,1
    • Lift the metal casing off of the hard drive.
  19. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 19 中的图像 1,1
    • Remove and set aside the black protector that was under the hard drive casing.
  20. PowerBook 3400 M3553 Hard Drive Replacement: 步骤 20 中的图像 1,3 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 20 中的图像 2,3 PowerBook 3400 M3553 Hard Drive Replacement: 步骤 20 中的图像 3,3
    • If your replacement drive did not come with a ribbon cable, use a plastic opening tool to remove the ribbon cable from your old hard drive.
    • Use a plastic opening tool to loosen the ribbon cable by running it along the connection and gently prying it free.
    • When you have loosened the connection, pull the tab to remove the ribbon cable.
结论
Install the new hard drive by following these instructions in reverse order.
6等其他人完成本指南。
团队
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G59
4 名成员
创作了9篇指南
2条评论
Thanks for the great guide! I used this guide on my Original PowerBook G3 (Kanga / 3500). Thank you!
Stephen - 回复
Looks like a excellent guide. I have a Kanga waiting and now I will make a plan
dscpinc - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 21
总计 5,855
