跳转到主内容
简介
Before performing any maintenance or repairs ensure that the PowerBook is unplugged and the battery has been removed.
  1. Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. Hold the button on the front left side and slide the battery out. Hold the button on the front left side and slide the battery out.
    • Hold the button on the front left side and slide the battery out.
结论
To reassemble your device, simply slide the battery back into the slot until it snaps into place.
4等其他人完成本指南。
Michael Mondragon
于2011年04月12日注册
193 信誉积分
创作了9篇指南
团队
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G59
4 名成员
创作了9篇指南
hey, I was wandering how do i replace the PRAM battery. If you know how i will apriciatte if you post a guide of how to do it. thanks
TOBI Pugli - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 11
总计 2,066
