跳转到主内容
PowerBook 3400 M3553 Battery Replacement
  1. PowerBook 3400 M3553 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Battery Replacement: 步骤 2 中的图像 1,2 PowerBook 3400 M3553 Battery Replacement: 步骤 2 中的图像 2,2
    • Hold the button on the front left side and slide the battery out.
结论
To reassemble your device, simply slide the battery back into the slot until it snaps into place.
5等其他人完成本指南。
团队
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G59
4 名成员
创作了9篇指南
1指南评论
hey, I was wandering how do i replace the PRAM battery. If you know how i will apriciatte if you post a guide of how to do it. thanks
TOBI Pugli - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 92
总计 2,773
