跳转到主内容
PowerBook 180 Modem Replacement
你所需要的
  1. PowerBook 180 Modem Replacement, Modem: 步骤 1 中的图像 1,2 PowerBook 180 Modem Replacement, Modem: 步骤 1 中的图像 2,2
    • Remove the Ni-Cad battery from the PowerBook 180.
    • Slide the arrows toward the front of the computer until the battery can slide out.
  2. PowerBook 180 Modem Replacement: 步骤 2 中的图像 1,2 PowerBook 180 Modem Replacement: 步骤 2 中的图像 2,2
    • Removing the screws securing the bottom plate from the PowerBook 180.
    • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  3. PowerBook 180 Modem Replacement: 步骤 3 中的图像 1,2 PowerBook 180 Modem Replacement: 步骤 3 中的图像 2,2
    • Your computer should look like the two pictures after the bottom plate is removed.
  4. PowerBook 180 Modem Replacement: 步骤 4 中的图像 1,2 PowerBook 180 Modem Replacement: 步骤 4 中的图像 2,2
    • Locate the modem board, which is next to the DC-in port.
    • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
    • To reassemble your PowerBook, follow these instructions in reverse.
结论
3等其他人完成本指南。
Jack Byrnes
于10/17/10注册
1,244 声望
创作了2篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,466篇指南
一条评论
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 1,627
