跳转到主内容
PowerA Spectra Infinity Enhanced Joysticks Replacement
你所需要的
  1. PowerA Spectra Infinity Enhanced Joysticks Replacement, Motherboard: 步骤 1 中的图像 1,2 PowerA Spectra Infinity Enhanced Joysticks Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Flip the controller so the back is facing up.
  2. PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
  3. PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 3 中的图像 1,2 PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 3 中的图像 2,2
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
  4. PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 4 中的图像 1,1
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
  5. PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 5 中的图像 1,2 PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 5 中的图像 2,2
    • Use your hand to separate the motherboard from the face plate.
  6. PowerA Spectra Infinity Enhanced Joysticks Replacement, Joysticks: 步骤 6 中的图像 1,1
    • Take the motherboard and place it with the joysticks facing upward.
  7. PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 7 中的图像 1,3 PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 7 中的图像 2,3 PowerA Spectra Infinity Enhanced Joysticks Replacement: 步骤 7 中的图像 3,3
    • Use your hand to carefully remove the joysticks from the motherboard.
结论
6等其他人完成本指南。
Kevyn Jorge
于03/22/24注册
1,018 声望
创作了6篇指南
团队
UMass Dartmouth, Team 6-5, Botvin Spring 2024 UMass Dartmouth, Team 6-5, Botvin Spring 2024 的会员
UMASSD-BOTVIN-S24S6G5
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 33
过去 30 天: 134
总计 1,734
