跳转到主内容
PowerA Enhanced1516953-01 Vibration Motors Replacement
你所需要的
  1. PowerA Enhanced1516953-01 Vibration Motors Replacement, Rear Case: 步骤 1 中的图像 1,3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Rear Case: 步骤 1 中的图像 2,3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Lay the controller face down.
    • Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
    • Lift the rear case up and off of the chassis.
  2. PowerA Enhanced1516953-01 Vibration Motors Replacement, Motherboard: 步骤 2 中的图像 1,3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Motherboard: 步骤 2 中的图像 2,3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
    • Lift the motherboard up and out of the chassis.
  3. PowerA Enhanced1516953-01 Vibration Motors Replacement, Vibration Motors: 步骤 3 中的图像 1,3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Vibration Motors: 步骤 3 中的图像 2,3 PowerA Enhanced1516953-01 Vibration Motors Replacement, Vibration Motors: 步骤 3 中的图像 3,3
    • Grip the white vibration motor connectors and pull them straight up and out of their sockets.
    • Do not pull on the wires.
    • Gently pull the connector from the pins
  4. PowerA Enhanced1516953-01 Vibration Motors Replacement: 步骤 4 中的图像 1,2 PowerA Enhanced1516953-01 Vibration Motors Replacement: 步骤 4 中的图像 2,2
    • Remove the four 3.3 mm Phillips screws that secure the motors.
    • Two screws secure each motor.
    • Once the second screw is removed on each motor, the vibration motor will immediately release itself. Support the motor while you remove the second screw.
结论
Austin Fox
于01/30/24注册
590 声望
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 369
