跳转到主内容
PowerA Enhanced Wireless Controller L and R buttons Replacement
你所需要的
  1. PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 步骤 1 中的图像 1,3 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 步骤 1 中的图像 2,3 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 2 中的图像 1,1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 3 中的图像 1,2 PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 3 中的图像 2,2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 4 中的图像 1,3 PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 4 中的图像 2,3 PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 4 中的图像 3,3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 步骤 5 中的图像 1,3 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 步骤 5 中的图像 2,3 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: 步骤 5 中的图像 3,3
    • Lift the two white latches using the iFixit opening tool.
    • Lift the white covering off.
  6. PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 6 中的图像 1,3 PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 6 中的图像 2,3 PowerA Enhanced Wireless Controller L and R buttons Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Squeeze the buttons with rubber tweezers and push them in.
    • Grab it from the back and pull it out.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S1-G5, Leahy Fall 2019 USF Tampa, Team S1-G5, Leahy Fall 2019 的会员
USFT-LEAHY-F19S1G5
3 名成员
创作了11篇指南
2指南评论
I need to know how to fix the ZR and the ZL buttons, like a faster response time
Starry Milligan - 回复
im sure this would be really helpful if i knew where i could buy the parts?
arch1e b - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 53
总计 4,054
