简介
The motherboard is the most important tool for the Xbox controller, the motherboard is the circuitry behind the device that makes it perform functions. In this guide, we are dissembling the controller to get to the motherboard.
你所需要的
Lay the controller face down.
Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
Lift the rear case up and off of the chassis.
Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
Lift the motherboard up and out of the chassis.
即将完成!
结论
