跳转到主内容
Power Macintosh G3 Minitower Processor Module Wire Screw Replacement
你所需要的
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Lay the computer on its side, ensuring that where the side access panel was is facing up.
    • Unlock the top chassis by moving the two green locking latches upward and outward.
    • Using the handle, gently swing the top chassis up and out until it rests firmly on the work surface.
    • Using a Phillips screwdriver, unscrew the screw on the logic board holding the processor module wire in place.
    • When screwing down the wire, be careful not to damage the capacitor next to the screw hole.
结论
LeoI07
于06/10/21注册
1,573 声望
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 85
