跳转到主内容
Power Macintosh G3 Blue and White Modem Replacement
你所需要的
  1. Power Macintosh G3 Blue and White Modem Replacement, Before opening up your Power Mac...: 步骤 1 中的图像 1,1
    • Remove the Phillips #1 screw circled in the picture. Set it aside for re-assembly.
  2. Power Macintosh G3 Blue and White Modem Replacement: 步骤 2 中的图像 1,1
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  3. Power Macintosh G3 Blue and White Modem Replacement: 步骤 3 中的图像 1,1
    • Remove the single Phillips #1 screw circled in the picture.
    • I apologize for the lack of picture quality. The only camera and lighting I had were my iPhone X´s camera and a table lamp. Lol!
  4. Power Macintosh G3 Blue and White Modem Replacement: 步骤 4 中的图像 1,1
    • Disconnect the modem’s flex cable from the connector on the logic board.
    • Lift the modem assembly out of it´s place on the logic board.
结论
2等其他人完成本指南。
[deleted]
于08/28/18注册
26,409 声望
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 645
