跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Power Macintosh G3 Blue and White Graphics Card Replacement
你所需要的
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: 步骤 1 中的图像 1,1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: 步骤 2 中的图像 1,2 Power Macintosh G3 Blue and White Graphics Card Replacement: 步骤 2 中的图像 2,2
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: 步骤 3 中的图像 1,1
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
结论
2等其他人完成本指南。
[deleted]
于08/28/18注册
26,298 声望
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 1,514
