跳转到主内容
Power Mac G5 Top Left Cooling Fan Unit Replacement
  1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: 步骤 1 中的图像 1,1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Top Left Cooling Fan Unit Replacement: 步骤 2 中的图像 1,1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Top Left Cooling Fan Unit Replacement: 步骤 3 中的图像 1,2 Power Mac G5 Top Left Cooling Fan Unit Replacement: 步骤 3 中的图像 2,2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Top Left Cooling Fan Unit Replacement: 步骤 4 中的图像 1,3 Power Mac G5 Top Left Cooling Fan Unit Replacement: 步骤 4 中的图像 2,3 Power Mac G5 Top Left Cooling Fan Unit Replacement: 步骤 4 中的图像 3,3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: 步骤 5 中的图像 1,1
    • Locate the top left cooling fan unit.
  6. Power Mac G5 Top Left Cooling Fan Unit Replacement: 步骤 6 中的图像 1,1
    • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
    • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
  7. Power Mac G5 Top Left Cooling Fan Unit Replacement: 步骤 7 中的图像 1,1
    • After pulling out the fan unit, the area should look like this.
结论
20等其他人完成本指南。
Salvador Aguilar
于01/21/10注册
2,550 声望
创作了3篇指南
团队
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 的会员
CPSU-FORTE-W10S5G8
7 名成员
创作了30篇指南
1指南评论
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 19,520
