跳转到主内容
Power Mac G5 PRAM Battery Replacement
  1. Power Mac G5 PRAM Battery Replacement, Side Panel: 步骤 1 中的图像 1,1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 PRAM Battery Replacement: 步骤 2 中的图像 1,1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 PRAM Battery Replacement: 步骤 3 中的图像 1,2 Power Mac G5 PRAM Battery Replacement: 步骤 3 中的图像 2,2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 PRAM Battery Replacement: 步骤 4 中的图像 1,3 Power Mac G5 PRAM Battery Replacement: 步骤 4 中的图像 2,3 Power Mac G5 PRAM Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 PRAM Battery Replacement, PRAM Battery: 步骤 5 中的图像 1,1
    • Locate the battery inside the desktop.
  6. Power Mac G5 PRAM Battery Replacement: 步骤 6 中的图像 1,3 Power Mac G5 PRAM Battery Replacement: 步骤 6 中的图像 2,3 Power Mac G5 PRAM Battery Replacement: 步骤 6 中的图像 3,3
    • Remove the battery by lifting the battery from the battery terminal.
    • Be careful to note which end is positive and which is negative. The positive end should be facing away from the PCI slots.
    • It is important to lift the battery as straight up as possible to avoid damage to battery or terminal.
    • The first photo shows the correct battery position. The last two photos show the battery facing the WRONG WAY! Remember, the positive end should be facing AWAY from the PCI slots, NOT towards them.
  7. Power Mac G5 PRAM Battery Replacement: 步骤 7 中的图像 1,1
    • The area should look like this after the battery is removed.
    • Be sure to properly dispose of the old battery after removal (take it to the nearest hazardous waste center).
    • Only insert LS1425OC 3.6V battery to prevent damage to the logic board.
结论
36等其他人完成本指南。
Nolan
于01/13/10注册
2,250 声望
创作了2篇指南
团队
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 的会员
CPSU-FORTE-W10S5G8
7 名成员
创作了30篇指南
7指南评论
plz advise the type of battery, thx !
adrianchan - 回复
Thank you, very very instructive - but why on Earth
does Apple not mark the battry holder on this model
with + and - ? ? Now, thanks to your close-up photo
I found out which way to turn the battery. (I hope)
Best regards
Torben, Denmark
Torben Hellborn -
Agreed - slot should be marked with + and – . . .
Thanks for the clear and sharp photos d;-)
Andrew Lawes - 回复
This is not valid for the late 2005 model of G5…Model 11,2.
It uses a coin shaped Panasonic Lithium battery. I just ordered one from OWC.
($.88)
Sari - 回复
Grazie, molto utile! Alberto da Venezia
favarettostudio - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 153
总计 78,766
