跳转到主内容
Power Mac G5 Hard Drive Replacement
你所需要的
  1. Power Mac G5 Hard Drive Replacement, Side Panel: 步骤 1 中的图像 1,1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Hard Drive Replacement: 步骤 3 中的图像 1,2 Power Mac G5 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Hard Drive Replacement: 步骤 4 中的图像 1,3 Power Mac G5 Hard Drive Replacement: 步骤 4 中的图像 2,3 Power Mac G5 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Locate hard drive on the top right-hand corner of the desktop.
  6. Power Mac G5 Hard Drive Replacement: 步骤 6 中的图像 1,2 Power Mac G5 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Rotate up plastic tab labeled "B" on the right hand side of hard drive.
  7. Power Mac G5 Hard Drive Replacement: 步骤 7 中的图像 1,2 Power Mac G5 Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Detach both cables from the hard drive.
  8. Power Mac G5 Hard Drive Replacement: 步骤 8 中的图像 1,2 Power Mac G5 Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Pull out the hard drive out.
  9. Power Mac G5 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • After hard drive is out, the space should look like this.
结论
102等其他人完成本指南。
Jessica Chaidez
于01/13/10注册
8,052 声望
创作了3篇指南
团队
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 的会员
CPSU-FORTE-W10S5G8
7 名成员
创作了30篇指南
8指南评论
I don't see why you'd need to remove the plastic cover
Petteri - 回复
I've tried many times to remove this and my other misplaced comment duplicate, but here they'll stay apparently... you're free to delete them if you can.
Petteri -
REMOVE the plastic cover to avoid knocking it off in the process of working on the drive bays. (Just a precaution - kind of like not setting a glass of red wine on an elegant white table cloth.)
EyeSpye -
The Comments appended to these instructions are VERY helpful. If you read them you will save time, and avoid some of the mistakes I made - particularly with respect to the Drive mounting screws located to the left side of the drive installation bays, and the need to remove the bottom drive FIRST if you wish to access the top drive. THANKS for a great set of instructions.
EyeSpye - 回复
This was helpful! Excellent photographs and clear, simple instructions. Thanks, Jessica and iFixit!
I used these instructions to remove an additional hard drive while leaving the original hard drive in place. I did not know which one to remove, as the hard drives do not have side labels, so I guessed: the original drive was on top, the additional drive on the bottom. It might be helpful for other viewers to know what to do in a similar situation.
Cheers.
Sharine Borslien - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 59
过去 30 天: 212
总计 86,752
