当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
Remove all the cables, including the power cables before opening the unit.
Lift the tab to unlock the side panel.
The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
Remove the air deflector (the clear plastic cover) by pulling on the handle.
Locate the front fan assembly.
Pull the fan assembly out; it should slide out easily.
取消:我没有完成这个指南。
25等其他人完成本指南。
与6其他贡献者
于01/22/10注册
831 声望
创作了3篇指南
徽章: 12
+ 9更多徽章
CPSU-FORTE-W10S5G8
7 名成员
创作了20篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 28
总计 18,898
