当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
The handle to open your computer is located on top of the right side panel.
Grab the circular handle and pull outward.
Your computer is now open and ready for repair.
The optical drive is in the top left corner of the case.
There are four screws to be removed.
The first screw can be seen in the first picture.
The remaining three screws can be seen in the second picture.
Remove the optical drive by pulling the drive away from the front of the computer and out.
Detach the two cables attached to the back of the drive.
The flat ribbon cable can be detached by pulling the silver tab. The multicolored cable can be removed by grasping the plastic connector on either side and pulling with substantial force.
Remove the four screws holding the enclosure to the drive.
Push on the back of the drive (side with the connectors) to slide the drive out of the enclosure.
Your optical drive is now ready to be replaced.
取消:我没有完成这个指南。
8等其他人完成本指南。
与2其他贡献者
于01/20/10注册
1,325 声望
创作了5篇指南
徽章: 12
+ 9更多徽章
CPSU-REGAN-W10S14G41
4 名成员
创作了17篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 11,234
