跳转到主内容
Power Mac G4 Quicksilver Optical Drive Disassembly
你所需要的
  1. Power Mac G4 Quicksilver Optical Drive Disassembly, Opening the case: 步骤 1 中的图像 1,1
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Optical Drive Disassembly: 步骤 2 中的图像 1,2 Power Mac G4 Quicksilver Optical Drive Disassembly: 步骤 2 中的图像 2,2
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Optical Drive Disassembly: 步骤 3 中的图像 1,1
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Optical Drive Disassembly, Optical Drive: 步骤 4 中的图像 1,1
    • The optical drive is in the top left corner of the case.
  5. Power Mac G4 Quicksilver Optical Drive Disassembly: 步骤 5 中的图像 1,2 Power Mac G4 Quicksilver Optical Drive Disassembly: 步骤 5 中的图像 2,2
    • There are four screws to be removed.
    • The first screw can be seen in the first picture.
    • The remaining three screws can be seen in the second picture.
  6. Power Mac G4 Quicksilver Optical Drive Disassembly: 步骤 6 中的图像 1,1
    • Remove the optical drive by pulling the drive away from the front of the computer and out.
  7. Power Mac G4 Quicksilver Optical Drive Disassembly: 步骤 7 中的图像 1,1
    • Detach the two cables attached to the back of the drive.
    • The flat ribbon cable can be detached by pulling the silver tab. The multicolored cable can be removed by grasping the plastic connector on either side and pulling with substantial force.
结论
7等其他人完成本指南。
Jacob Garcia
于01/28/10注册
621 声望
创作了2篇指南
团队
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G41
4 名成员
创作了27篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 5,883
