跳转到主内容
Power Mac G4 Quicksilver Hard Drive Replacement
你所需要的
  1. Power Mac G4 Quicksilver Hard Drive Replacement, Opening the case: 步骤 1 中的图像 1,1
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 2 中的图像 1,2 Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • The hard drive is located in the rear right corner of the case.
  5. Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Unplug the IDE ribbon cable. This is the wide flat grey cable.
  6. Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 6 中的图像 1,2 Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Remove the screw holding down the hard drive enclosure.
  7. Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Lift the hard drive enclosure straight up and out.
    • Be carful not to pull the attached cable.
  8. Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Disconnect the MOLEX connector.
    • This cable may be hard to remove. Grab the connector on either side as pictured and wiggle it back and forth to remove it.
  9. Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the four screws holding the hard drive to the enclosure.
  10. Power Mac G4 Quicksilver Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Your hard drive is now free from the enclosure and is ready to be replaced.
结论
8等其他人完成本指南。
Ryan Bylard
于01/20/10注册
1,325 声望
创作了5篇指南
团队
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G41
4 名成员
创作了27篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 15,661
