跳转到主内容
Power Mac G4 Quicksilver Central Processing Unit Replacement
你所需要的
  1. Power Mac G4 Quicksilver Central Processing Unit Replacement, Opening the case: 步骤 1 中的图像 1,1
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 2 中的图像 1,2 Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 2 中的图像 2,2
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 3 中的图像 1,1
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Central Processing Unit Replacement, Video Adapter: 步骤 4 中的图像 1,1
    • This is your Power Mac G4's video adapter.
  5. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 5 中的图像 1,1
    • Start by removing the screw holding the card to the chassis as shown.
  6. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 6 中的图像 1,1
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  7. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 7 中的图像 1,2 Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 7 中的图像 2,2
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  8. Power Mac G4 Quicksilver Central Processing Unit Replacement, Central Processing Unit: 步骤 8 中的图像 1,1
    • First you want to remove the fan. Remove the two screws on the back of the computer in the upper left hand corner.
  9. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 9 中的图像 1,2 Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 9 中的图像 2,2
    • Remove the fan unit by pulling straight up and out.
    • Be carful not to rip out the cord still attached to the motherboard. Remove it gently.
  10. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 10 中的图像 1,2 Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 10 中的图像 2,2
    • You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side.
    • Taking off the clamps can be difficult. Use a screwdriver to push down on the top of the clip. Then insert a spudger below the heat sink to pull it away from the board, releasing the heat sink.
  11. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 11 中的图像 1,2 Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 11 中的图像 2,2
    • Pull the heat sink up and off of the CPU.
  12. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 12 中的图像 1,1
    • Remove the four screws holding the CPU to the motherboard.
  13. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 13 中的图像 1,2 Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 13 中的图像 2,2
    • Now you can remove the CPU by pulling it straight up from the motherboard.
    • Be very careful when you detach the CPU. There is a connector that has hundreds of little prongs. You must not bend or break any of them! Be extremely careful.
  14. Power Mac G4 Quicksilver Central Processing Unit Replacement: 步骤 14 中的图像 1,1
    • You can now replace the CPU.
结论
11等其他人完成本指南。
Ryan Bylard
于01/20/10注册
1,325 声望
创作了5篇指南
团队
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G41
4 名成员
创作了17篇指南
一条评论
Removing graphics (video) card is not necessary. Also, removing the clips which retain heat-sink can be accomplished by using a flat-blade (-) screwdriver to carefully pry them from the finned aluminum assembly. Other than these two suggestions, guide is succinct and accurate.
analogcd - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 31
总计 11,585
