跳转到主内容
Power Mac G4 MDD Optical Drive Cage Replacement
你所需要的
  1. Power Mac G4 MDD Optical Drive Cage Replacement, Case: 步骤 1 中的图像 1,2 Power Mac G4 MDD Optical Drive Cage Replacement, Case: 步骤 1 中的图像 2,2
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 2 中的图像 1,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 2 中的图像 2,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 2 中的图像 3,3
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD Optical Drive Cage Replacement, Hard Drives: 步骤 3 中的图像 1,1
    • The hard drive cages are located here.
  4. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 4 中的图像 1,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 4 中的图像 2,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 4 中的图像 3,3
    • Cage 1
    • Start by removing this screw.
    • Remove the ATA-66/ IDE ribbon cable from the motherboard.
  5. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 5 中的图像 1,2 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 5 中的图像 2,2
    • Now, remove the power connection from the drives.
  6. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 6 中的图像 1,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 6 中的图像 2,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 6 中的图像 3,3
    • Push this tab down, and pull the cage toward you.
    • Now, you can set cage 1 aside.
  7. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 7 中的图像 1,2 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 7 中的图像 2,2
    • Cage 2:
    • Remove this Phillips screw:
    • Disconnect this IDE ribbon cable from the logic board.
  8. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 8 中的图像 1,2 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 8 中的图像 2,2
    • It's likely that there is a cable clip holding the ribbon cable to the case.
    • To remove it, push the end, and it should pop up.
  9. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 9 中的图像 1,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 9 中的图像 2,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 9 中的图像 3,3
    • With the ribbon cable clip free, pull this tab towards you, slide the cage up until it hits the platform under the power supply, and pull it away.
    • Now, set the cage on top of the CPU, and remove the power connectors.
  10. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 10 中的图像 1,2 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 10 中的图像 2,2
    • Once the cables are free, set the drive cage aside.
    • To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, then slide the drives out.
    • The two cages are cross compatible and can be put in either location.
    • The MDD does not have a 128GB drive limit like older Macs. My MDD has 3 drives (a 400GB Hitatchi Deskstar, 40GB Seagate Barracuda 7200.7, and a 30GB Quantum Fireball LCT).
    • Note the ID jumpers on the two drive set. One is set to Master, the other to slave. A single drive can be set to Cable Select.
  11. Power Mac G4 MDD Optical Drive Cage Replacement, Optical Drive Cage: 步骤 11 中的图像 1,2 Power Mac G4 MDD Optical Drive Cage Replacement, Optical Drive Cage: 步骤 11 中的图像 2,2
    • Start removing the optical drive cage by removing its back cover.
  12. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 12 中的图像 1,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 12 中的图像 2,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 12 中的图像 3,3
    • Now, remove the IDE and power cables from the drives.
  13. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 13 中的图像 1,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 13 中的图像 2,3 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 13 中的图像 3,3
    • Remove these two Phillips screws:
    • Pull the cage away from the front until it is free.
    • Slide the cage towards you, and out of the Mac.
  14. Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 14 中的图像 1,2 Power Mac G4 MDD Optical Drive Cage Replacement: 步骤 14 中的图像 2,2
    • To remove the drive(s) from the cage, remove the two screws on each side of the drive(s), then pull the drive out of the cage.
    • My MDD has a 3rd party 22X SuperDrive, for burning DVD's in Leopard (Thank You Generic Drive Support!)
结论
16等其他人完成本指南。
Chris Green
于10/11/09注册
38,086 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,454篇指南
1指南评论
In the Sacramento FATP factory we used to call this the 'media can' in previous models because there were other drives such as ZIP and JAZZ drives available, until this and the one just prior which only had optical drive options, so it became the 'optical cage'
joey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 30
总计 12,762
