跳转到主内容
Power Mac G4 MDD AirPort Card Replacement
你所需要的
  1. Power Mac G4 MDD AirPort Card Replacement, Case: 步骤 1 中的图像 1,2 Power Mac G4 MDD AirPort Card Replacement, Case: 步骤 1 中的图像 2,2
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD AirPort Card Replacement: 步骤 2 中的图像 1,3 Power Mac G4 MDD AirPort Card Replacement: 步骤 2 中的图像 2,3 Power Mac G4 MDD AirPort Card Replacement: 步骤 2 中的图像 3,3
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD AirPort Card Replacement, AirPort Card: 步骤 3 中的图像 1,3 Power Mac G4 MDD AirPort Card Replacement, AirPort Card: 步骤 3 中的图像 2,3 Power Mac G4 MDD AirPort Card Replacement, AirPort Card: 步骤 3 中的图像 3,3
    • The AirPort card is located next to the graphics card.
    • If your computer has a FireWire 800 port between the FireWire 400 Ports and the Ethernet Ports then your computer uses an AirPort Extreme 802.11g Card (See Related Parts). If your computer has no firewire 800 port, then your computer uses an 802.11b AirPort PCMCIA Card (Also See Related Parts). Removal of both cards is pretty much the same.
    • First disconnect the antenna from the card, it may be helpful to use a spudger or flathead screwdriver.
    • Now, grasp the plastic tab on the back of the card and pull it out of the computer.
  4. Power Mac G4 MDD AirPort Card Replacement: 步骤 4 中的图像 1,1
    • The Airport 802.11b PCMCIA Card.
结论
13等其他人完成本指南。
Chris Green
于10/11/09注册
38,086 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,452篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 40
总计 29,344
