跳转到主内容
Power Mac G4 M5183 Processor Replacement
你所需要的
  1. Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 1,2 Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 2,2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - 回复
  2. Power Mac G4 M5183 Processor Replacement, Heat Sink: 步骤 2 中的图像 1,2 Power Mac G4 M5183 Processor Replacement, Heat Sink: 步骤 2 中的图像 2,2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Processor Replacement: 步骤 3 中的图像 1,1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Processor Replacement, Processor: 步骤 4 中的图像 1,2 Power Mac G4 M5183 Processor Replacement, Processor: 步骤 4 中的图像 2,2
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
终点
13等其他人完成本指南。
Justin Petrilli
于01/21/10注册
3,114 声望
创作了11篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
2条评论
anyone still sell the replacement processor?
Joseph Cole - 回复
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 41
总计 12,091
