跳转到主内容
Power Mac G4 M5183 Power Supply Replacement
你所需要的
  1. Power Mac G4 M5183 Power Supply Replacement, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 1,2 Power Mac G4 M5183 Power Supply Replacement, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 2,2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Power Supply Replacement, Main Fan: 步骤 2 中的图像 1,2 Power Mac G4 M5183 Power Supply Replacement, Main Fan: 步骤 2 中的图像 2,2
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Power Mac G4 M5183 Power Supply Replacement: 步骤 3 中的图像 1,1
    • Remove the power cable from the fan and detach bracing.
  4. Power Mac G4 M5183 Power Supply Replacement, DVD-ROM Drive: 步骤 4 中的图像 1,2 Power Mac G4 M5183 Power Supply Replacement, DVD-ROM Drive: 步骤 4 中的图像 2,2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  5. Power Mac G4 M5183 Power Supply Replacement: 步骤 5 中的图像 1,1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  6. Power Mac G4 M5183 Power Supply Replacement: 步骤 6 中的图像 1,3 Power Mac G4 M5183 Power Supply Replacement: 步骤 6 中的图像 2,3 Power Mac G4 M5183 Power Supply Replacement: 步骤 6 中的图像 3,3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
  7. Power Mac G4 M5183 Power Supply Replacement, Power Supply: 步骤 7 中的图像 1,2 Power Mac G4 M5183 Power Supply Replacement, Power Supply: 步骤 7 中的图像 2,2
    • Remove the 3 hex screws on the back of the case.
    • Remove the single screw on the side of the power supply casing with the Phillips #1 screwdriver.
  8. Power Mac G4 M5183 Power Supply Replacement: 步骤 8 中的图像 1,2 Power Mac G4 M5183 Power Supply Replacement: 步骤 8 中的图像 2,2
    • Remove power cable from the logic board.
    • Remove power cable from hard drive.
    • Pull the power supply out and towards yourself.
终点
18等其他人完成本指南。
Justin Petrilli
于01/21/10注册
3,114 声望
创作了11篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
3条评论
Had a nearby lightning strike, "scrammed" my Mac, but couldn't start it up afterwards. Google led me to the ifixit site ( where I should have gone first!) and your instructions got me going again. Granted, I had an identical, spare Macintosh so I was able to pull that power supply to replace the damaged one and not have to wait for a replacement, but your step-by-step made the swap fairly easy! Thank you! I am happy tonight!
Now to order the replacement.
Bill Pitts - 回复
Hello Bill, I was wondering what power supply did you order as a replacement. Getting an original would cost over $100 almost next to $200, so I want to make sure where else I can buy a good power supply. Thanks in advance.
Andrew R. -
ditto…. like Bill I had a faithful G4 i use to archive some old OS9 files that need specific software that never went to OS X and some very basic Apache web server stuff. Mostly sleeping it went pop one day, I had replaced it a few years previously after a pram issue with a clean SH unit which i just swopped drives over, so getting sleeping beauty down from attic, following instructions I removed the power pac and in 30 minus the dead mac was running again and archive is protected
ipodista - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 37
总计 23,511
