当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Pull on outer latch.
Lower door until it is level with your work surface.
Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
Remove the power cable from the fan and detach bracing.
To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
取消:我没有完成这个指南。
3等其他人完成本指南。
与4其他贡献者
于01/20/10注册
2,238 声望
创作了2篇指南
徽章: 13
+ 10更多徽章
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 37
总计 7,727
