跳转到主内容
Power Mac G4 M5183 Main Fan Replacement
你所需要的
  1. Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 1,2 Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 2,2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Main Fan Replacement, Main Fan: 步骤 2 中的图像 1,2 Power Mac G4 M5183 Main Fan Replacement, Main Fan: 步骤 2 中的图像 2,2
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Power Mac G4 M5183 Main Fan Replacement: 步骤 3 中的图像 1,1
    • Remove the power cable from the fan and detach bracing.
  4. Power Mac G4 M5183 Main Fan Replacement, Main Fan: 步骤 4 中的图像 1,1
    • To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
结论
3等其他人完成本指南。
Stephen Scruggs
于01/20/10注册
2,238 声望
创作了2篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 41
总计 7,792
