跳转到主内容
Power Mac G4 M5183 Logic Board Replacement
你所需要的
  1. Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 1,2 Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 2,2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - 回复
  2. Power Mac G4 M5183 Logic Board Replacement, Heat Sink: 步骤 2 中的图像 1,2 Power Mac G4 M5183 Logic Board Replacement, Heat Sink: 步骤 2 中的图像 2,2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Logic Board Replacement: 步骤 3 中的图像 1,1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Logic Board Replacement, RAM: 步骤 4 中的图像 1,2 Power Mac G4 M5183 Logic Board Replacement, RAM: 步骤 4 中的图像 2,2
    • Locate the RAM modules.
    • Pull side tabs outward. The RAM will pop out of the housing.
  5. Power Mac G4 M5183 Logic Board Replacement, Graphics Card: 步骤 5 中的图像 1,2 Power Mac G4 M5183 Logic Board Replacement, Graphics Card: 步骤 5 中的图像 2,2
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
  6. Power Mac G4 M5183 Logic Board Replacement, Logic Board: 步骤 6 中的图像 1,2 Power Mac G4 M5183 Logic Board Replacement, Logic Board: 步骤 6 中的图像 2,2
    • Remove the six indicated cables attached to the logic board.
    • Use the spudger to remove the modem cable as indicated.
  7. Power Mac G4 M5183 Logic Board Replacement: 步骤 7 中的图像 1,2 Power Mac G4 M5183 Logic Board Replacement: 步骤 7 中的图像 2,2
    • Unfasten 3 Phillips screws revealed beneath the heat sink on the CPU board.
    • Carefully remove the CPU board from the Mother Board.
    • Remove the barrell nut screws from the Mother Board which held the CPU board.
    • Unfasten 3 Phillips #1 screws on Mother Board as shown in illustration 1.
    • Slide the logic board about a quarter of an inch to free it from the three retaining pins.
    • Pull upwards and outwards to fully remove the logic board.
  8. Power Mac G4 M5183 Logic Board Replacement: 步骤 8 中的图像 1,1
    • After removing the (3) #2 philips screws, remove the (4) 1/4" hex nuts, then slide as directed and remove board.
终点
15等其他人完成本指南。
Justin Petrilli
于01/21/10注册
3,114 声望
创作了11篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
3条评论
Are the "hex nuts" under the processor board? Could you provide a close up picture of the "nuts?"
D george - 回复
So what is being replaced here? Wouldn’t one have to purchase a new logic board? Any info would be greatly appreciated!
Sandra Cai - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 38
总计 17,863
