跳转到主内容
简介
Replacing the internal battery which regulates several functions in the computer, including the calendar.
  1. Pull on outer latch. Lower door until it is level with your work surface.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - 回复
  2. Locate the battery. Remove and replace battery.
    • Locate the battery.
    • Remove and replace battery.
    • Push the PMU button once, and only once, to reset the power supply.
终点
19等其他人完成本指南。
Justin Petrilli
于2010年01月21日注册
3,030 信誉积分
创作了11篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了25篇指南
3条评论
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Lars-Peter Jorgensen - 回复
Not bad, but PMU button location is not explained… the button on the front to start it?
rwwseditor - 回复
Hi
Will a 3V Lithium battery work or must it be 3.6V?
Please advise.
Rgds
Duard
Duard Kleyn - 回复
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 37
过去的30天: 133
总计 21,459
