当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
Push back the handle after you have taken the core out of the case.
Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
Slowly lift the plate off the cube and disconnect the power cord.
Remove the four pillars from each corner.
The pillars should come out fairly easily.
Remove the screws on the back of the VGA port.
Remove the screw attaching the video card to the logic board.
Remove power cord from the video card.
Remove the power cord.
Remove the connector.
Remove the video card from the logic board.
Carefully lift the video card from the logic board.
The video card should come out easily.
Separate the video card from the adapter.
取消:我没有完成这个指南。
9等其他人完成本指南。
与4其他贡献者
于06/24/10注册
1,076 声望
创作了7篇指南
徽章: 13
+ 10更多徽章
CPSU-JOHANN-R10S2G7
5 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 43
总计 10,560
