你所需要的
这个步骤还没有翻译 帮忙翻译一下
Removing the Ram
Start by fliping the cube so that the side with the graphics card is facing you, you may want to push the handle back in.
There are 3 RAM Slots, they are Standard PC100 Ram. The cube can support up to 1.5GB of ram, that's a 512MB Stick In All 3 Slots.
Remove the ram, just like any other kind of ram.
这个步骤还没有翻译 帮忙翻译一下
Removing the AGP Riser card
Pull the card out of the PCI Socket, and no, unfortunately, you can't use this to put an AGP card in a PCI slot in a PC.
Once the card is free, mind the 3 cables attached to it, remove these 2 cables first.
The third cable is glued to the AGP board, unplug it from the logic board instead.
这个步骤还没有翻译 帮忙翻译一下
Removing the Voltage Regulator Module.
This board is called the DC/DC board, or the Voltage Regulator Module. It takes the power from the power brick and regulates the power to different components of the Cube.
First, disconnect the power connector.
Then release the white clip on the connector socket, which is accessed from the side of the core.
With a little persuasion, the board comes out of it's socket(it's hard to show how the board comes out, but in person, it's pretty self explanatory)
这个步骤还没有翻译 帮忙翻译一下
The Logic Board
Unfortunately, this as far as I am going to dissect my cube, partially because I still use it frequently, but here is an overview of the cube.
450Mhz or 500Mhz PowerPC G4 Processor
Shipped with 64MB ram, supports up to 1.5GB of PC100 or PC133
One PCI Slot(Converted to AGP via adaptor)
No Onboard Audio.(Unfortunately)
8条评论
This is great! What a beautiful machine that was.
Kyle Wiens - 回复
Awesome teardown, Chris! Thanks for posting it.
