跳转到主内容
Power Mac G4 Cube RAM Replacement
你所需要的
  1. Power Mac G4 Cube RAM Replacement, Outer Case: 步骤 1 中的图像 1,3 Power Mac G4 Cube RAM Replacement, Outer Case: 步骤 1 中的图像 2,3 Power Mac G4 Cube RAM Replacement, Outer Case: 步骤 1 中的图像 3,3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube RAM Replacement: 步骤 2 中的图像 1,2 Power Mac G4 Cube RAM Replacement: 步骤 2 中的图像 2,2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube RAM Replacement: 步骤 3 中的图像 1,1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube RAM Replacement, RAM: 步骤 5 中的图像 1,2 Power Mac G4 Cube RAM Replacement, RAM: 步骤 5 中的图像 2,2
    • Flip the two latches on the side of the RAM chip.
    • Remove the chip from the logic board and replace with new RAM.
结论
11等其他人完成本指南。
Ryan Chun
于06/24/10注册
1,076 声望
创作了7篇指南
团队
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G7
5 名成员
创作了21篇指南
1指南评论
Unless you have really fat fingers, you shouldn’t need to remove the metal plate and pillars. I’m able to replace the RAM without those steps.
Chris Sebes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 5,935
