跳转到主内容
Power Mac G4 Cube Modem Replacement
你所需要的
  1. Power Mac G4 Cube Modem Replacement, Outer Case: 步骤 1 中的图像 1,3 Power Mac G4 Cube Modem Replacement, Outer Case: 步骤 1 中的图像 2,3 Power Mac G4 Cube Modem Replacement, Outer Case: 步骤 1 中的图像 3,3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Modem Replacement: 步骤 2 中的图像 1,2 Power Mac G4 Cube Modem Replacement: 步骤 2 中的图像 2,2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Modem Replacement: 步骤 3 中的图像 1,1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Modem Replacement: 步骤 4 中的图像 1,1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Modem Replacement, Video Card: 步骤 5 中的图像 1,1
    • Remove the screws on the back of the VGA port.
  6. Power Mac G4 Cube Modem Replacement: 步骤 6 中的图像 1,1
    • Remove the screw attaching the video card to the logic board.
  7. Power Mac G4 Cube Modem Replacement: 步骤 7 中的图像 1,2 Power Mac G4 Cube Modem Replacement: 步骤 7 中的图像 2,2
    • Remove power cord from the video card.
  8. Power Mac G4 Cube Modem Replacement: 步骤 8 中的图像 1,1
    • Remove the power cord.
    • Remove the connector.
    • Remove the video card from the logic board.
  9. Power Mac G4 Cube Modem Replacement: 步骤 9 中的图像 1,1
    • Carefully lift the video card from the logic board.
    • The video card should come out easily.
  10. Power Mac G4 Cube Modem Replacement: 步骤 10 中的图像 1,2 Power Mac G4 Cube Modem Replacement: 步骤 10 中的图像 2,2
    • Separate the video card from the adapter.
  11. Power Mac G4 Cube Modem Replacement, Modem: 步骤 11 中的图像 1,1
    • Remove the two screws from the modem.
  12. Power Mac G4 Cube Modem Replacement: 步骤 12 中的图像 1,1
    • Lift modem from the Logic Board.
    • The modem should come out easily.
结论
3等其他人完成本指南。
Ryan Chun
于06/24/10注册
1,076 声望
创作了7篇指南
团队
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G7
5 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 4,445
