跳转到主内容
Power Mac G4 Cube Hard drive Replacement
你所需要的
  1. Power Mac G4 Cube Hard drive Replacement, Outer Case: 步骤 1 中的图像 1,3 Power Mac G4 Cube Hard drive Replacement, Outer Case: 步骤 1 中的图像 2,3 Power Mac G4 Cube Hard drive Replacement, Outer Case: 步骤 1 中的图像 3,3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Hard drive Replacement: 步骤 2 中的图像 1,2 Power Mac G4 Cube Hard drive Replacement: 步骤 2 中的图像 2,2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Hard drive Replacement: 步骤 3 中的图像 1,1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Hard drive Replacement: 步骤 4 中的图像 1,1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Hard drive Replacement, Hard drive: 步骤 5 中的图像 1,1
    • Lift Airport slot.
  6. Power Mac G4 Cube Hard drive Replacement: 步骤 6 中的图像 1,1
    • Remove the power cord from the hard drive.
    • Remove the IDE cable from the hard drive.
    • Grip the sides of the hard drive and slowly pull outward.
  7. Power Mac G4 Cube Hard drive Replacement: 步骤 7 中的图像 1,1
    • Remove the three top screws of the hard drive use a T8 bit and remove the heat sink.
    • Carefully slide the hard drive to the open side (side without the IDE and power cables) to remove the drive.
    • Turn the drive over, remove the sled rail with a T10 driver for its two screws. Transfer the rail to the same side on the new drive.
    • Insert new hard drive.
结论
21等其他人完成本指南。
Ryan Chun
于06/24/10注册
1,076 声望
创作了7篇指南
团队
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G7
5 名成员
创作了14篇指南
一条评论
Strictly speaking, steps 2 through 4 aren’t necessary: you can just unscrew the heatsink from the hard drive, as in step 7, and carefully lift it out (I found that tilting it toward the optical drive and then pivoting it out worked).
bobtheflyingsquirrel - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 86
总计 17,702
