跳转到主内容
Power Mac G4 Cube Airport Card Replacement
  1. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: 步骤 1 中的图像 1,3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: 步骤 1 中的图像 2,3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: 步骤 1 中的图像 3,3
    • Release the handle at the bottom of the Power Mac G4 Cube by pushing it down. Slowly pull out the cube by holding the end of the handle.
    • Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: 步骤 2 中的图像 1,2 Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: 步骤 2 中的图像 2,2
    • Pull outwards on the antenna cable.
    • The cable should pop out of the card without much force.
    • Pull on the clear tab outwards to remove the existing AirPort card
    • Slide in the new AirPort card.
    • Reconnect the antenna cable.
结论
8等其他人完成本指南。
Ryan Chun
于06/24/10注册
1,076 声望
创作了7篇指南
团队
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G7
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 35
总计 9,929
