跳转到主内容
Power Index System Rear Derailleur Adjustment
你所需要的
  1. Power Index System Rear Derailleur Adjustment, Power Index System Rear Derailleur Adjustment: 步骤 1 中的图像 1,1
    • Turn the bicycle upside down. Usually you would rest your bicycle on both wheels, instead now you will be resting it on the seat (try resting on a surface that doesn’t damage it).
  2. Power Index System Rear Derailleur Adjustment: 步骤 2 中的图像 1,3 Power Index System Rear Derailleur Adjustment: 步骤 2 中的图像 2,3 Power Index System Rear Derailleur Adjustment: 步骤 2 中的图像 3,3
    • Switch the bicycles chain to the lowest chainring on the rear crankset of the bicycle. (If the derailleur is faulty it may not allow you to do this so you may have to manually roll the back tire while shifting the chain onto the smallest chainring).
  3. Power Index System Rear Derailleur Adjustment: 步骤 3 中的图像 1,2 Power Index System Rear Derailleur Adjustment: 步骤 3 中的图像 2,2
    • Loosen the rear screw which holds the derailleur against the frame of the bicycle and take out the derailleur slowly
    • (The derailleur is held in tension so be careful not to let it snap out instantly).
    • Take the chain off the crankset as well.
  4. Power Index System Rear Derailleur Adjustment: 步骤 4 中的图像 1,2 Power Index System Rear Derailleur Adjustment: 步骤 4 中的图像 2,2
    • Use wrench to loosen bolt that holds back tension wire
  5. Power Index System Rear Derailleur Adjustment: 步骤 5 中的图像 1,1
    • Turn in the direction of H on the handle until it can turn anymore
  6. Power Index System Rear Derailleur Adjustment: 步骤 6 中的图像 1,2 Power Index System Rear Derailleur Adjustment: 步骤 6 中的图像 2,2
    • Pull the tension wire to maximum tension (as far back as it will let you) and then tighten the bolt with wrench while maintaining that tension
  7. Power Index System Rear Derailleur Adjustment: 步骤 7 中的图像 1,1
    • Get the chain back on the biggest chainring/sprocket in the rear crankset.
  8. Power Index System Rear Derailleur Adjustment: 步骤 8 中的图像 1,1
    • After adjusting the derailleur, get the derailleur in the correct position it should be against the bicycle rear hub .
  9. Power Index System Rear Derailleur Adjustment: 步骤 9 中的图像 1,1
    • Screw the nut that holds the derailleur firmly in place and make sure it is very tight against the bicycle frame.
  10. Power Index System Rear Derailleur Adjustment: 步骤 10 中的图像 1,2 Power Index System Rear Derailleur Adjustment: 步骤 10 中的图像 2,2
    • The derailleur has two screws, the low adjusting screw which controls how far the derailleur moves towards the wheel and the high adjusting screw which controls how far it can move away from the wheel.
    • Adjust these screws with the screwdriver until it positions the derailleur in such a way that the front handle (shown earlier) can be used to switch from the highest to the lowest chainrings/sprockets on the rear crankset
结论
Izakuk
于02/03/25注册
181 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 465
