跳转到主内容
Power Button Replacement
你所需要的
  1. Power Button Replacement, Open electronics case: 步骤 1 中的图像 1,2 Power Button Replacement, Open electronics case: 步骤 1 中的图像 2,2
    • Gently pull apart the two sides of the plastic case. This will reveal the circuit board an battery.
    • Using a Torx 6 Screw driver, loosen and store the 3 screws at the bottom side of the case.
  2. Power Button Replacement, Disconnect Battery: 步骤 2 中的图像 1,2 Power Button Replacement, Disconnect Battery: 步骤 2 中的图像 2,2
    • Look for the white plastic battery connector at the base of the circuit board.
    • Carefully grip and pull out the white battery connector. If there is silicone or glue be mindful not to apply much force to prevent the entire connector to come loose from circuity board.
    • Keep battery aside.
  3. Power Button Replacement, Circuit board removal: 步骤 3 中的图像 1,2 Power Button Replacement, Circuit board removal: 步骤 3 中的图像 2,2
    • Using a Torx 6 scredriver, remove the (2) screws holding the circuit board
    • With the help of a flat tool, pry the circuit board off the plastic case.
  4. Power Button Replacement: 步骤 4 中的图像 1,3 Power Button Replacement: 步骤 4 中的图像 2,3 Power Button Replacement: 步骤 4 中的图像 3,3
    • With aid of a pointy tool, push the damaged flexible button from the top down.
    • Using the fingers, insert the new flexible button from the top-down into the case opening. Make sure the button flange is not folded.
结论
BRIGHT Products
于11/06/23注册
144 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 309
