跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters
你所需要的
  1. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters, Replacing Damaged Primer Bulb and Fuel Lines: 步骤 1 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters, Replacing Damaged Primer Bulb and Fuel Lines: 步骤 1 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters, Replacing Damaged Primer Bulb and Fuel Lines: 步骤 1 中的图像 3,3
    • Start by unscrewing the (3) T25 screws on the top cover
    • Remove the top cover and set aside
  2. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 2 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 2 中的图像 2,2
    • With the top cover off, disconnect the sparkplug
  3. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 3 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 3 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 3 中的图像 3,3
    • Remove the (4) T25 screws securing the starter assembly to the (side) of the chainsaw
    • Remove the starter assembly and set aside
  4. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 4 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 4 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 4 中的图像 3,3
    • Remove the air filter cover and set aside
    • Remove the air filter from the housing and set aside
  5. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 5 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 5 中的图像 2,2
    • Unscrew the (1) T25 screw securing the air filter housing to the carburetor
    • Remove the (2) 5/16"nuts securing the air filter housing to the carburetor
  6. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 6 中的图像 1,1
    • Disconnect the kill switch wire by using a flat head screw driver
  7. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 7 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 7 中的图像 2,2
    • Remove the air filter housing from the carburetor
    • Let the air filter housing rest on the side of the chainsaw
  8. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 8 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 8 中的图像 2,2
    • Using a flat head screw driver disconnect the (primer-side) fuel line from the carburetor.
  9. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 9 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 9 中的图像 2,2
    • Remove the choke lever from the carburetor and set aside
  10. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 10 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 10 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 10 中的图像 3,3
    • Pull and hold the throttle trigger to expose the throttle linkage attachment point (on the trigger)
    • Disconnect the linkage from the throttle trigger
    • Disconnect and remove the throttle linkage from the carburetor
    • Set the throttle linkage aside
  11. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 11 中的图像 1,1
    • Slide the carburetor assembly off the mounting bolts and away from the engine
    • The fuel return line may be still attached to the carburetor. In my case the fuel line was disintegrated. If it is still attached remove with a flat head screw driver
  12. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 12 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 12 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 12 中的图像 3,3
    • Using a flat head screwdriver press the tabs on the inside of the primer bulb assembly. (This will release the primer bulb from the housing)
    • Pull the damaged primer bulb out of the engine housing
    • Use long needle nosed pliers to disconnect the (2) fuel lines from the primer bulb.
  13. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 13 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 13 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 13 中的图像 3,3
    • If the primer suction line was damaged, slide the carburetor back onto the mounting bolts
    • Attach one end of the new fuel line to the incoming fuel port on the carburetor
    • Move the fuel line through the primer bulb housing and hold the primer bulb up to the fuel line
    • Mark desired length and cut to size
    • If the old primer suction line was intact, you can measure and cut a new piece of fuel line to the same length and attach it to the intake port on the primer bulb and intake port on the carburetor.
  14. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 14 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 14 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 14 中的图像 3,3
    • Attach the cut end of the primer fuel line to the intake port of the primer bulb (shorter nipple)
    • Slide the carburetor back off of the mounting bolts
    • Cut and remove the remaining old fuel lines by pulling them through the housing
  15. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 15 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 15 中的图像 2,2
    • Unscrew and remove the gas cap
    • Pull out and remove old fuel lines and fuel filter
  16. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 16 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 16 中的图像 2,2
    • This is an example of how the fuel lines will attach to the carburetor and primer bulb
  17. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 17 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 17 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 17 中的图像 3,3
    • Push a piece of scrap wire through the larger hole (fuel filter line)
    • Use a pair of long needle nose pliers or hemostats to grab the other end through the gas tank
  18. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 18 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 18 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 18 中的图像 3,3
    • Cut a piece of the thicker diameter fuel line at a sharp angle
    • Pierce the wire through the fuel line and twist the wire with pliers
  19. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 19 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 19 中的图像 2,2
    • Feed the fuel line through the gas tank while pulling the wire.
    • Use pliers to continue to pull the fuel line through the housing
  20. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 20 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 20 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 20 中的图像 3,3
    • Feed the wire through the small hole (fuel return)
    • Attach the wire to the cut end of the thinner diameter fuel line as in the previous step
    • Feed the fuel line through the gas tank while pulling the wire as in the previous step
    • Pull both fuel lines up through the housing
  21. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 21 中的图像 1,1
    • Using 2-cycle oil as lubricant on the fuel lines will make it easier to pull them through the housing
  22. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 22 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 22 中的图像 2,2
    • Cut both of the fuel lines flush (removing the angle that was previously cut)
  23. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 23 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 23 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 23 中的图像 3,3
    • Attach the larger diameter fuel line (fuel filter line) to the intake inlet on the carburetor
    • Attach the smaller diameter fuel line (fuel return line) to the return port on the primer bulb (longer nipple)
    • Slide the carburetor back onto the mounting bolts while pulling out the slack out of the fuel lines from the gas tank
  24. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 24 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 24 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 24 中的图像 3,3
    • Push the primer bulb back into the housing
    • Cut the smaller diameter fuel line (fuel return line) and push it into the gas tank
    • The fuel return line should be at the bottom of the tank
  25. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 25 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 25 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 25 中的图像 3,3
    • Cut the fuel filter line and attach the new fuel filter
    • Push the fuel filter line into the gas tank
    • The fuel filter should rest at the bottom of the gas tank
  26. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 26 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 26 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 26 中的图像 3,3
    • Reconnect the throttle linkage to the carburetor linkage
    • Pull and hold the throttle trigger to expose the attachment point for the trigger-portion of the throttle linkage
    • Connect the throttle linkage to the throttle trigger
  27. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 27 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 27 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 27 中的图像 3,3
    • Reconnect the choke lever
    • Slide the air filter housing back onto the carburetor mounting bolts
    • Secure the air filter housing with the (2) 5/16" nuts
    • Secure air filter housing with (1) T25 screw
  28. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 28 中的图像 1,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 28 中的图像 2,3 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 28 中的图像 3,3
    • Install the new air filter onto the air filter housing
    • Install the air filter cover
    • Connect the kills witch wire
  29. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 29 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 29 中的图像 2,2
    • Install the starter assembly onto the engine
    • Secure the starter assembly with (4) T25 screws
    • Pull the starter rope slowly until the flywheel engages the starter assembly
  30. Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 30 中的图像 1,2 Poulan P3314 2-Cycle Chainsaw: Replace Primer Bulb, Fuel Lines, and Filters: 步骤 30 中的图像 2,2
    • Reconnect the spark plug
    • Install the top cover and secure with (3) T25 screws
结论
38等其他人完成本指南。
Chad Monteleone
于09/18/17注册
1,148 声望
撰写一个指南
团队
Pasco Hernando, Team S4-G44, Prince Fall 2017 Pasco Hernando, Team S4-G44, Prince Fall 2017 的会员
PHSC-PRINCE-F17S4G44
1 名成员
创作了4篇指南
20条评论
Any idea where I downloaded shop manuals for small engin repairs looking for stihl 039 manual
Daniel - 回复
Yes I would try manuals.lib at the Google play store.
Randy Clawson -
Daniel. Here you go. Hope this works out for you.
https://m.stihlusa.com/WebContent/CMSFil...
Robert Spillman - 回复
Excellent instructions
Thank You
Ron Bishop - 回复
How do you choose the best choose the best product among the ones listed here? <a href="https://onlychainsaw.com/best-scroll-saw... ">https://onlychainsaw.com/best-scroll-saw... </a>
ross jonnes - 回复
添加评论
浏览统计数据:
过去 24 小时: 30
过去 7 天: 225
过去 30 天: 968
总计 84,160
