跳转到主内容
简介
Almost all gas now contains up to 10% ethanol. Ethanol is one of the leading causes of damage to small gas engines. The alcohol can cause corrosion on rubber and plastic parts and can make gas powered yard tools almost impossible to start. I will illustrate how to replace the parts that are most common to fail,the primer bulb and fuel lines. While disassembled I will also illustrate how to replace the fuel filter and air filter of the Poulan P3314 2-Cycle Chainsaw.
  1. Start by unscrewing the (3) T25 screws on the top cover Remove the top cover and set aside Remove the top cover and set aside
    • Start by unscrewing the (3) T25 screws on the top cover
    • Remove the top cover and set aside
  2. With the top cover off, disconnect the sparkplug With the top cover off, disconnect the sparkplug
    • With the top cover off, disconnect the sparkplug
  3. Remove the (4) T25 screws securing the starter assembly to the (side) of the chainsaw Remove the starter assembly and set aside Remove the starter assembly and set aside
    • Remove the (4) T25 screws securing the starter assembly to the (side) of the chainsaw
    • Remove the starter assembly and set aside
  4. Remove the air filter cover and set aside Remove the air filter from the housing  and set aside Remove the air filter from the housing  and set aside
    • Remove the air filter cover and set aside
    • Remove the air filter from the housing and set aside
  5. Unscrew the (1) T25 screw securing the air filter housing to the carburetor Remove the (2) 5/16"nuts securing the air filter housing to the carburetor
    • Unscrew the (1) T25 screw securing the air filter housing to the carburetor
    • Remove the (2) 5/16"nuts securing the air filter housing to the carburetor
  6. Disconnect the kill switch wire by using a flat head screw driver
    • Disconnect the kill switch wire by using a flat head screw driver
  7. Remove the air filter housing from the carburetor Let the air filter housing rest on the side of the chainsaw
    • Remove the air filter housing from the carburetor
    • Let the air filter housing rest on the side of the chainsaw
  8. Using a flat head screw driver disconnect the (primer-side) fuel line from the carburetor. Using a flat head screw driver disconnect the (primer-side) fuel line from the carburetor.
    • Using a flat head screw driver disconnect the (primer-side) fuel line from the carburetor.
  9. Remove the choke lever from the carburetor and set aside Remove the choke lever from the carburetor and set aside
    • Remove the choke lever from the carburetor and set aside
  10. Pull and hold the throttle trigger to expose the throttle linkage attachment point (on the trigger) Disconnect the linkage from the throttle trigger Disconnect and remove the throttle linkage from the carburetor
    • Pull and hold the throttle trigger to expose the throttle linkage attachment point (on the trigger)
    • Disconnect the linkage from the throttle trigger
    • Disconnect and remove the throttle linkage from the carburetor
    • Set the throttle linkage aside
  11. Slide the carburetor assembly off the mounting bolts and away from the engine
    • Slide the carburetor assembly off the mounting bolts and away from the engine
    • The fuel return line may be still attached to the carburetor. In my case the fuel line was disintegrated. If it is still attached remove with a flat head screw driver
  12. Using a flat head screwdriver press the tabs on the inside of the primer bulb assembly. (This will release the primer bulb from the housing) Pull the damaged primer bulb out of the engine housing Use long needle nosed pliers to disconnect the (2) fuel lines from the primer bulb.
    • Using a flat head screwdriver press the tabs on the inside of the primer bulb assembly. (This will release the primer bulb from the housing)
    • Pull the damaged primer bulb out of the engine housing
    • Use long needle nosed pliers to disconnect the (2) fuel lines from the primer bulb.
  13. If the primer suction line was damaged, slide the carburetor back onto the mounting bolts Attach one end of the new fuel line to the  incoming fuel port on the carburetor Move the fuel line through the primer bulb housing and hold the primer bulb up to the fuel line
    • If the primer suction line was damaged, slide the carburetor back onto the mounting bolts
    • Attach one end of the new fuel line to the incoming fuel port on the carburetor
    • Move the fuel line through the primer bulb housing and hold the primer bulb up to the fuel line
    • Mark desired length and cut to size
    • If the old primer suction line was intact, you can measure and cut a new piece of fuel line to the same length and attach it to the intake port on the primer bulb and intake port on the carburetor.
  14. Attach the cut end of the primer fuel line to the intake port of the primer bulb (shorter nipple) Slide the carburetor back off of the mounting bolts Cut and remove the remaining old fuel lines by pulling them through the housing
    • Attach the cut end of the primer fuel line to the intake port of the primer bulb (shorter nipple)
    • Slide the carburetor back off of the mounting bolts
    • Cut and remove the remaining old fuel lines by pulling them through the housing
  15. Unscrew and remove the gas cap Pull out and remove old fuel lines and fuel filter
    • Unscrew and remove the gas cap
    • Pull out and remove old fuel lines and fuel filter
  16. This is an example of how the fuel lines will attach to the carburetor and primer bulb This is an example of how the fuel lines will attach to the carburetor and primer bulb
    • This is an example of how the fuel lines will attach to the carburetor and primer bulb
    I want to see how the fuel filter fits inside the fuel tank. I can’t keep it from leaking around the tubing.
    Larry Mayer - 回复
  17. Push a piece of scrap wire through the larger hole (fuel filter line) Use a pair of long needle nose pliers or hemostats to grab the other end through the gas tank Use a pair of long needle nose pliers or hemostats to grab the other end through the gas tank
    • Push a piece of scrap wire through the larger hole (fuel filter line)
    • Use a pair of long needle nose pliers or hemostats to grab the other end through the gas tank
  18. Cut a piece of the thicker diameter fuel line at a sharp angle Pierce the wire through the fuel line and twist the wire with pliers Pierce the wire through the fuel line and twist the wire with pliers
    • Cut a piece of the thicker diameter fuel line at a sharp angle
    • Pierce the wire through the fuel line and twist the wire with pliers
  19. Feed the fuel line through the gas tank while pulling the wire. Use pliers to continue to pull the fuel line through the housing
    • Feed the fuel line through the gas tank while pulling the wire.
    • Use pliers to continue to pull the fuel line through the housing
  20. Feed the wire through the small hole (fuel return) Attach the wire to the cut end of the thinner diameter fuel line as in the previous step Feed the fuel line through the gas tank while pulling the wire as in the previous step
    • Feed the wire through the small hole (fuel return)
    • Attach the wire to the cut end of the thinner diameter fuel line as in the previous step
    • Feed the fuel line through the gas tank while pulling the wire as in the previous step
    • Pull both fuel lines up through the housing
  21. Using 2-cycle oil as lubricant on the fuel lines will make it easier to pull them through the housing
    • Using 2-cycle oil as lubricant on the fuel lines will make it easier to pull them through the housing
  22. Cut both of the fuel lines flush (removing the angle that was previously cut) Cut both of the fuel lines flush (removing the angle that was previously cut)
    • Cut both of the fuel lines flush (removing the angle that was previously cut)
  23. Attach the larger diameter fuel line (fuel filter line) to the intake inlet on the carburetor Attach the smaller diameter fuel line (fuel return line) to the return port on the primer bulb (longer nipple) Slide the carburetor back onto the mounting bolts while pulling out the slack out of the fuel lines from the gas tank
    • Attach the larger diameter fuel line (fuel filter line) to the intake inlet on the carburetor
    • Attach the smaller diameter fuel line (fuel return line) to the return port on the primer bulb (longer nipple)
    • Slide the carburetor back onto the mounting bolts while pulling out the slack out of the fuel lines from the gas tank
    What’s the name of that small black tap look piece?
    Jessica Rios - 回复
  24. Push the primer bulb back into the housing Cut the smaller diameter fuel line (fuel return line) and push it into the gas tank The fuel return line should be at the bottom of the tank
    • Push the primer bulb back into the housing
    • Cut the smaller diameter fuel line (fuel return line) and push it into the gas tank
    • The fuel return line should be at the bottom of the tank
  25. Cut the fuel filter line and attach the new fuel filter Push the fuel filter line  into the gas tank The fuel filter should rest at the bottom of the gas tank
    • Cut the fuel filter line and attach the new fuel filter
    • Push the fuel filter line into the gas tank
    • The fuel filter should rest at the bottom of the gas tank
  26. Reconnect the throttle linkage to the carburetor linkage Pull and hold the throttle trigger to expose the attachment point for the trigger-portion of the throttle linkage Connect the throttle linkage to the throttle trigger
    • Reconnect the throttle linkage to the carburetor linkage
    • Pull and hold the throttle trigger to expose the attachment point for the trigger-portion of the throttle linkage
    • Connect the throttle linkage to the throttle trigger
  27. Reconnect the choke lever Slide the air filter housing back onto the carburetor mounting bolts Secure the air filter housing with the (2) 5/16" nuts
    • Reconnect the choke lever
    • Slide the air filter housing back onto the carburetor mounting bolts
    • Secure the air filter housing with the (2) 5/16" nuts
    • Secure air filter housing with (1) T25 screw
  28. Install the new air filter onto the air filter housing Install the air filter cover Connect the kills witch wire
    • Install the new air filter onto the air filter housing
    • Install the air filter cover
    • Connect the kills witch wire
  29. Install the starter assembly onto the engine Secure the starter assembly with (4) T25 screws
    • Install the starter assembly onto the engine
    • Secure the starter assembly with (4) T25 screws
    • Pull the starter rope slowly until the flywheel engages the starter assembly
  30. Reconnect the spark plug Install the top cover and secure with  (3) T25 screws
    • Reconnect the spark plug
    • Install the top cover and secure with (3) T25 screws
结论
28等其他人完成本指南。
Chad Monteleone
于2017年09月18日注册
884 信誉积分
撰写一个指南
团队
Pasco Hernando, Team S4-G44, Prince Fall 2017 Pasco Hernando, Team S4-G44, Prince Fall 2017 的会员
PHSC-PRINCE-F17S4G44
1 名成员
创作了2篇指南
14条评论
Any idea where I downloaded shop manuals for small engin repairs looking for stihl 039 manual
Daniel - 回复
Yes I would try manuals.lib at the Google play store.
Randy Clawson -
Daniel. Here you go. Hope this works out for you.
https://m.stihlusa.com/WebContent/CMSFil...
Robert Spillman - 回复
Excellent instructions
Thank You
Ron Bishop - 回复
How do you choose the best choose the best product among the ones listed here? <a href="https://onlychainsaw.com/best-scroll-saw... ">https://onlychainsaw.com/best-scroll-saw... </a>
ross jonnes - 回复
Thank You very good .
snowbugca - 回复
Excellent job in describing the process! Thanks!!
Antonio Gutierrez - 回复
Hello, I noticed you might have gotten your fuel lines mixed up. Im not sure if it would make any difference in the operation of the chainsaw.
But during the disassembly stage, you have the thick fuel return line going from the purge bulb outlet port to the big hole towards the front of the fuel tank. Yet during the reassembly stage, you used this same hole for your fuel supply line instead.
The correct routing of the fuel lines is actually the way it was before you disassembled it.
Basically:
1: Thin line from right carburetor nipple gets routed through the small hole towards the rear of the fuel tank and is hooked up to the fuel filter inside.
2: Thick line goes from left carburetor nipple to the short nipple on the purge bulb.
3: And finally, another thick line goes from the long nipple of the purge bulb to the big hole towards the front of the fuel tank.
ajisup - 回复
Hey Chad, thanks a bunch for a an excellent set of instructions. You saved me a lot of time and money!
Judas - 回复
Great information here, I’ll use it to do the same job on my McCulloch 2214AV, it is almost identical to this Poulan.
Greg Bell - 回复
:) very helpful!
joethef - 回复
very clear and well explained, I followed instructions and replaced both fuel lines. The fuel, heat and time just disintegrates these lines. Thanks
Joel Sanchez - 回复
Thank you so much for all the time and effort to make the tough job of replacing fuel lines in these Poulan saws easier. Your thorough step-by-step instruction and photos are really appreciated. Very well done, Sir!
Lynn Wilkens Anderson - 回复
The above article is beneficial for me because here details show how to fix chainsaws. Those people are constructive who have Poulan P3314 chainsaw. Thanks for sharing with us.
Anthony - 回复
添加评论
浏览统计数据:
过去的24小时: 25
过去的7天: 226
过去的30天: 944
总计 49,487
