跳转到主内容
Poukaran ZRW-TD-SRK2 LED Replacement
你所需要的
  1. Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: 步骤 1 中的图像 1,3 Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: 步骤 1 中的图像 2,3 Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: 步骤 1 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the 7.5mm screws securing the front of the lamp's outer casing or lid.
  2. Poukaran ZRW-TD-SRK2 LED Replacement: 步骤 2 中的图像 1,3 Poukaran ZRW-TD-SRK2 LED Replacement: 步骤 2 中的图像 2,3 Poukaran ZRW-TD-SRK2 LED Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the last two 7.5 mm screws securing the back of the lamp's outer casing or lid.
  3. Poukaran ZRW-TD-SRK2 LED Replacement: 步骤 3 中的图像 1,2 Poukaran ZRW-TD-SRK2 LED Replacement: 步骤 3 中的图像 2,2
    • Once the lid is off, locate and remove the top plate covering the internal components of the lamp.
  4. Poukaran ZRW-TD-SRK2 LED Replacement: 步骤 4 中的图像 1,3 Poukaran ZRW-TD-SRK2 LED Replacement: 步骤 4 中的图像 2,3 Poukaran ZRW-TD-SRK2 LED Replacement: 步骤 4 中的图像 3,3
    • Use a soldering iron to carefully desolder the wires connecting the faulty LED strips. Ensure you're desoldering the correct connections. Solder the new LED strips in place, connecting the wires securely to the designated points on the lamp's circuit board.
    • Exercise caution when lifting the plate that holds the LEDs, as there is a risk of accidentally pulling out the wires.
结论
To reassemble your device, follow these instructions in reverse order. Ensure each component is securely in place and all connections are properly aligned.
andrez oceguera
于08/23/23注册
109 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-1, Briggs Fall 2023 CSU Los Angeles, Team 2-1, Briggs Fall 2023 的会员
CSULA-BRIGGS-F23S2G1
6 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 75
