跳转到主内容
Porter-Cable PCE211 Rear Housing Replacement
你所需要的
  1. Porter-Cable PCE211 Rear Housing Replacement, Rear Housing: 步骤 1 中的图像 1,2 Porter-Cable PCE211 Rear Housing Replacement, Rear Housing: 步骤 1 中的图像 2,2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  2. Porter-Cable PCE211 Rear Housing Replacement: 步骤 2 中的图像 1,2 Porter-Cable PCE211 Rear Housing Replacement: 步骤 2 中的图像 2,2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
结论
Layla Berry
于09/19/22注册
678 声望
创作了7篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 69
