跳转到主内容
Porter-Cable PCE211 Grip Replacement
你所需要的
  1. Porter-Cable PCE211 Grip Replacement, Gearcase: 步骤 1 中的图像 1,2 Porter-Cable PCE211 Grip Replacement, Gearcase: 步骤 1 中的图像 2,2
    • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
  2. Porter-Cable PCE211 Grip Replacement: 步骤 2 中的图像 1,3 Porter-Cable PCE211 Grip Replacement: 步骤 2 中的图像 2,3 Porter-Cable PCE211 Grip Replacement: 步骤 2 中的图像 3,3
    • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
    • Be careful about any loose parts when removing the head.
  3. Porter-Cable PCE211 Grip Replacement, Rear Housing: 步骤 3 中的图像 1,2 Porter-Cable PCE211 Grip Replacement, Rear Housing: 步骤 3 中的图像 2,2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  4. Porter-Cable PCE211 Grip Replacement: 步骤 4 中的图像 1,2 Porter-Cable PCE211 Grip Replacement: 步骤 4 中的图像 2,2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
  5. Porter-Cable PCE211 Grip Replacement, Anvil: 步骤 5 中的图像 1,3 Porter-Cable PCE211 Grip Replacement, Anvil: 步骤 5 中的图像 2,3 Porter-Cable PCE211 Grip Replacement, Anvil: 步骤 5 中的图像 3,3
    • Firmly pull the to remove drill bit holder also known as the anvil.
    • Before replacing the anvil, lubricate the base for the best performance.
  6. Porter-Cable PCE211 Grip Replacement, Motor: 步骤 6 中的图像 1,3 Porter-Cable PCE211 Grip Replacement, Motor: 步骤 6 中的图像 2,3 Porter-Cable PCE211 Grip Replacement, Motor: 步骤 6 中的图像 3,3
    • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
    • Pull the motor out with your hands.
  7. Porter-Cable PCE211 Grip Replacement: 步骤 7 中的图像 1,3 Porter-Cable PCE211 Grip Replacement: 步骤 7 中的图像 2,3 Porter-Cable PCE211 Grip Replacement: 步骤 7 中的图像 3,3
    • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
  8. Porter-Cable PCE211 Grip Replacement, Grip: 步骤 8 中的图像 1,2 Porter-Cable PCE211 Grip Replacement, Grip: 步骤 8 中的图像 2,2
    • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
  9. Porter-Cable PCE211 Grip Replacement: 步骤 9 中的图像 1,2 Porter-Cable PCE211 Grip Replacement: 步骤 9 中的图像 2,2
    • Pull the grip from the body of the impact wrench.
结论
另外一个人完成了本指南。
Layla Berry
于09/19/22注册
678 声望
创作了7篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 93
