跳转到主内容
Porter-Cable PC60TAG Power Cord Replacement
你所需要的
  1. Porter-Cable PC60TAG Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips head screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Power Cord Replacement: 步骤 2 中的图像 1,1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Power Cord Replacement: 步骤 3 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips head screws securing the cord grip.
  4. Porter-Cable PC60TAG Power Cord Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
  5. Porter-Cable PC60TAG Power Cord Replacement: 步骤 5 中的图像 1,1
    • Careful remove each wire from the power cord from underneath the terminals.
结论
团队
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 UMass Dartmouth, Team 2-2, Isaacson Spring 2016 的会员
UMASSD-ISAACSON-S16S2G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 457
