跳转到主内容
Porter-Cable PC60TAG Pinion Gear Replacement
你所需要的
  1. Porter-Cable PC60TAG Pinion Gear Replacement, Pinion Gear: 步骤 1 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
  2. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 2 中的图像 1,1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 3 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm. Repeat on the other side.
  4. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 4 中的图像 1,1
    • Carefully pull the motor brush arm away from the other device, you can leave the wire connected to device. Repeat on the other side.
  5. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the 1 inch black retainer screw.
  6. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the four, 1/2" Phillips screws around the head gear.
  7. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 7 中的图像 1,1
    • Carefully pull the head gear away from the device, and set aside.
  8. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips screws holding the head to the body on the bottom side of the grinder.
  9. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 9 中的图像 1,1
    • Using the Phillips #2 screwdriver, remove the other two 1/2" Phillips screws holding the head to the body on the top side of the grinder.
  10. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 10 中的图像 1,1
    • Holding the head of the device, carefully pull the motor assembly out of the body of the device.
  11. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 11 中的图像 1,1
    • Using a 9/16" wrench, loosen the spindle nut inside the head, from the motor assembly.
  12. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 12 中的图像 1,1
    • Pull the motor assembly away from the head, and set aside
  13. Porter-Cable PC60TAG Pinion Gear Replacement: 步骤 13 中的图像 1,1
    • Using a pair of needle nose pliers, remove the pinion gear from the head.
结论
团队
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 UMass Dartmouth, Team 2-2, Isaacson Spring 2016 的会员
UMASSD-ISAACSON-S16S2G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 655
