跳转到主内容
Porter-Cable 382 Sander Pad Replacement
你所需要的
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: 步骤 1 中的图像 1,1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: 步骤 2 中的图像 1,1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
结论
另外一个人完成了本指南。
Nick O'Sadcia
于03/11/16注册
421 声望
创作了3篇指南
团队
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 12
总计 1,778
