跳转到主内容
Porter-Cable 382 On/ Off Switch Replacement
你所需要的
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: 步骤 1 中的图像 1,2 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: 步骤 1 中的图像 2,2
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: 步骤 2 中的图像 1,2 Porter-Cable 382 On/ Off Switch Replacement: 步骤 2 中的图像 2,2
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: 步骤 3 中的图像 1,1
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
结论
Nick O'Sadcia
于03/11/16注册
421 声望
创作了3篇指南
团队
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 244
