跳转到主内容
加入维修社区 - 创建账户
Porter-Cable 382 Fan Replacement
你所需要的
  1. Porter-Cable 382 Fan Replacement, Sander Pad: 步骤 1 中的图像 1,1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Fan Replacement, Dust Seal/ Break: 步骤 3 中的图像 1,1
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Fan Replacement: 步骤 4 中的图像 1,2 Porter-Cable 382 Fan Replacement: 步骤 4 中的图像 2,2
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
  5. Porter-Cable 382 Fan Replacement, Fan: 步骤 5 中的图像 1,2 Porter-Cable 382 Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Once the dust brake/ seal is removed locate the screw in the center of the device holding down the bearing and fan assembly.
    • unscrew this bolt using a T20 star bit and carefully remove the washer and bearing as shown.
  6. Porter-Cable 382 Fan Replacement: 步骤 6 中的图像 1,1
    • Next locate the bolts holding down the guard assembly as shown. There will be one bolt on each side, two in total.
    • Using a T15 star bit unscrew these bolts and make sure you keep them in a safe place.
  7. Porter-Cable 382 Fan Replacement: 步骤 7 中的图像 1,1
    • Once the two screws are removed locate the o-ring that seals the dust collector to its opening.
    • Very delicately pry the o-ring out of its slot using a nylon spudger or plastic opening tool. Then roll it off of the opening as shown.
  8. Porter-Cable 382 Fan Replacement: 步骤 8 中的图像 1,2 Porter-Cable 382 Fan Replacement: 步骤 8 中的图像 2,2
    • Now the two guards will come apart as shown, giving you access to the fan.
    • During reassembly, the two guards will line up so that the dust collector opening lines up with the power cord as shown.
  9. Porter-Cable 382 Fan Replacement: 步骤 9 中的图像 1,1
    • The fan can then simply be pulled from its axle and be replaced with the fan blades facing up.
结论
另外一个人完成了本指南。
Nick O'Sadcia
于03/11/16注册
448 声望
创作了3篇指南
团队
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G7
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 504
