跳转到主内容
Porter Cable 690LR Power Switch Replacement
你所需要的
  1. Porter Cable 690LR Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,2 Porter Cable 690LR Power Switch Replacement, Power Switch: 步骤 1 中的图像 2,2
    • Use a Torx screwdriver to unscrew the 25.4 mm screws found at the top of the model.
  2. Porter Cable 690LR Power Switch Replacement: 步骤 2 中的图像 1,2 Porter Cable 690LR Power Switch Replacement: 步骤 2 中的图像 2,2
    • Remove the top by gently lifting the cover from router body.
    • Be careful when pulling the top from its place; wires connect the switch to the electrical cord and could be pulled loose or damaged.
  3. Porter Cable 690LR Power Switch Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to pull off the plastic covering of the power switch.
    • Don’t be afraid to really pry underneath the plastic (no components of the router will be damaged if you do so).
  4. Porter Cable 690LR Power Switch Replacement: 步骤 4 中的图像 1,1
    • Push the power switch through the top of the router. The power switch should now be completely detached from the router (besides the wire connections).
  5. Porter Cable 690LR Power Switch Replacement: 步骤 5 中的图像 1,2 Porter Cable 690LR Power Switch Replacement: 步骤 5 中的图像 2,2
    • Find the wire plugs which are attached to the power switch. These connections are located at the back of the plastic box that houses the switch.
    • Use the spudger to carefully loosen the metal and rubber coverings, and detach the connections from the switch.
    • While some force is needed in order to successfully pull the connections free, have care in making sure that you don’t damage any of the metal components. If needed you may carefully use a metal spudger instead of a plastic opening tool.
结论
2等其他人完成本指南。
Jaymes Ullrich
于10/05/16注册
343 声望
创作了3篇指南
团队
Cal Poly, Team 20-7, Livingston Fall 2016 Cal Poly, Team 20-7, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G7
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 16
总计 870
