跳转到主内容
加入维修社区 - 创建账户
Porter Cable 690LR Base Panel Replacement
你所需要的
  1. Porter Cable 690LR Base Panel Replacement, Base: 步骤 1 中的图像 1,2 Porter Cable 690LR Base Panel Replacement, Base: 步骤 1 中的图像 2,2
    • Undo the black latch located on the base of the router by pulling upwards from underneath it.
  2. Porter Cable 690LR Base Panel Replacement: 步骤 2 中的图像 1,2 Porter Cable 690LR Base Panel Replacement: 步骤 2 中的图像 2,2
    • Twist the base off the router.
    • You may need to jiggle the base of the router slightly.
  3. Porter Cable 690LR Base Panel Replacement, Base Panel: 步骤 3 中的图像 1,2 Porter Cable 690LR Base Panel Replacement, Base Panel: 步骤 3 中的图像 2,2
    • Orient the base so the black circular plate is facing you. Locate the three silver screw heads.
    • Use a flathead screwdriver to take off the three 10 mm screws.
结论
另外一个人完成了本指南。
Emma Stine
于10/06/16注册
273 声望
创作了2篇指南
团队
Cal Poly, Team 20-7, Livingston Fall 2016 Cal Poly, Team 20-7, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G7
4 名成员
创作了6篇指南
1指南评论
Aynı ürünü kullanıyorum..! Son birkaç yıldır Porter Cable ürünlerini kullanıyorum
Ancak bunu bu siteden satın aldım - https://www.raptorsupplies.com/b/porter-...
Omer Polat - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 306
